Passenger side axle seal-
91206-PHR-003
Driver side axle seal
91205-PL3-B01
Oil seal-
91216-PG1-005
this seal sits under the bearing for the main shaft where it slides through the transmission casing keeping oil inside the trans and out of the clutch housing.
Hope this helps.
Thank you for helping out [MENTION=56]PetefromtheStreets[/MENTION] I'm eager to see how things pan out! [MENTION=1241]K20JuJu[/MENTION] keep us updated!
