Pictures are back up from page 5 onwards.
I will come back to the rest of the pages and fix them up sooner or later.
Michael
Michael
What's up man. Welcome to the boards. That's a nice looking Teggy you had/have there. Sorry to hear about your friends teg though. So the bike rider was fine after that crash is what you said?
Welcome! So do you still have your integra? And yes is biker ok? I'm a little confused by the way you wrote it. That looks like a gnarly dent for just a bike!
welkome!!!!
I have a project phoenix yellow type r turbo under wraps in my garage!!!
(Technical issues with bandwidth limits)
Current Modification List to date are -
Engine
K24A3
* BluePrint Stage 2+ BILLET Camshafts
* BluePrint Valvetrain
* 50 Degree VTC
* Hasport Engine Mounts.
* Hondata Intake Manifold Gasket
* RBC Intake Manifold Match Ported to 70mm
* S90 70mm Throttle Body + Adapter
* K-Tuned Ram Intake + Velocity Stacker
* K-Tuned V2 TPS Sensor
* K-Tuned Coilpack Cover
* K-Tuned Valve Cover Breather Filter
* DTR/SSR K-swap Header
* 3'' 100cell cat
* 3'' exhaust system + 2 vibrant resonator + Varex chambered muffler
* Magnetic Oil + Transmission Sump Bolts
* Mugen Oil Cap
* Deka light weight Race Battery
* Hybrid Racing Ground Wiring Kit
Engine Management
* Hondata K Pro tuned by BYP @ 157.2 kw atw.
Transmission
* Jdm Ep3r Gearbox
* Exedy Heavy Duty Clutch
* Oem Lightweight Flywheel
* Oem LSD
* K-Tuned Billet Shifter Box
* Karcepts Shifter box mounting plate
* Hybrid Racing Gear Knob
Fuel Setup
* RDX 410cc Injectors + Injector Clips
* Walbro 255LPH Intank Fuel Pump
* K-Tuned Fuel Rail
* K-Tuned Fuel Pressure Gauge
* K-Tuned Fuel Pressure Regulator
* K-Tuned Slimline Fuel Filter
* K-Tuned Fuel Lines + Fittings
Cooling
* K-Tuned Half Size Radiator
* K-Tuned Radiator Hoses
* K-Tuned Swivel Neck Thermostat (185F)
* Fan Switch Via K-Pro Set At 195F
* 12'' Slimline Radiator fan
Suspension
* Zeal Function X coilovers
* Skunk 2 Front Camber Arms
* Unknown Rear Camber Arms
* Full Race Traction Bar
Chassis Reinforcement
* Edelbrock 3 point front strut tower brace
* Miracle X bar
* Beaks ( Gold ) Lower Tie Bar
Brakes
* Spoon Twin Block Brake Calipers
* Apexi GT Spec Front Brake Pads
* Project Mu Max 500 Rear Brake Pads
* App Braided Brake Lines
Wheels & Tyres
* Enkei Racing S 16x8 +32 x8
* Advan AD07 225-45-16
Interior
* Driver + Passenger Recaro sr3 nylon seat covers.
* Apexi RSM + G Sensor (Black Edition)
* Jdm Sun Visors
* Jdm Rear Seat Belt Buckle
* Jdm Red Stich boot
Exterior
* 98 Spec Jdm Front End Conversion
* BYS Front Bar
* OEM Optional Rear Pods
* OEM Optional Side Skirts
* OEM Window Visors
* Shark Attack 2 Antenna ( S2000 Rep)
* Rays Extended red wheel nuts
Hopefully I'll do well for my first time out. Got a feeling my tyres will be a let down.
Any tips on wheel alignment specs to maximize my potential?
